Skroot
Jun 06, 2020Follower
Laptops keep dropping wifi from satellite
Hey everyone, So as of a week ago my macbooks/windows laptops ONLY when connected to my orbi SATELLITE (RBS50) frequently drop wifi connection every 10 seconds or so. This DOES NOT affect iPhone...
Jun 06, 2020Guru - Experienced User
What is the mfr and model# of the laptop and the mfr and model# of the wifi adapter in the laptop.
Sure the wifi adapter drivers are up to date.
If this only happens with the laptops, then they may need more review.
Do they connect at the RBR with the RBS turned OFF?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
