GWild
Jul 20, 2020Guide
Latency Spikes
Includes an RBS20 Satellite ... which not seeing it in the pulldown above hints Netgear thinks it is no longer a salable item.
Issue is latency spikes between my workstation and the router/modem. Also the fact it drops packets is also a problem. This table was collected over a few hours of game and normal desktop use.
|--------------------------------------------------------------------------------------------| | WinMTR statistics | | Host - % | Sent | Recv | Best | Avrg | Wrst | Last | |------------------------------------------------|------|--------|------|------|------|------| | 192.168.1.1 - 1 | 17708 | 17707 | 1 | 2 | 878 | 2 | | 10.116.215.1 - 1 | 17687 | 17680 | 9 | 13 | 521 | 12 | | 192.168.69.153 - 1 | 17710 | 17709 | 9 | 13 | 410 | 11 | | 10.224.253.133 - 0 | 17712 | 17712 | 9 | 14 | 599 | 13 | | No response from host - 100 | 3595 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 3595 | 0 | 0 | 0 | 0 | 0 | | 4.7.26.166 - 1 | 17707 | 17706 | 47 | 55 | 409 | 70 | | ae1-br02-csla1.as57976.net - 1 | 17701 | 17698 | 73 | 78 | 893 | 76 | | xe-0-0-1-3-br02-eqla1.as57976.net - 1 | 17702 | 17700 | 47 | 62 | 1988 | 51 | | be3-pe02-eqla3.as57976.net - 1 | 17705 | 17703 | 0 | 79 | 306 | 77 | | 24.105.30.129 - 1 | 17709 | 17708 | 73 | 76 | 344 | 84 | |________________________________________________|_______|_______|______|______|______|______| WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
Sort By
Are you testing with ALL other devices disconnected from the system while your testing?
Wired or wireless connected when your testing this?
- GWildGuide
Of course this is a normal operating network, all devices are connected (many connect passively while powered off). Latest firmware available installed for router and satellite. Why would anyone expect a router to test perfectly in a perfect setting then stop working when you start to use it in the real world?
It's not so much an occasional slow response as a slow response with dropping packets. This is the first network router I have owned that has dropped ping packets. That's saying something since I've owned routers about as long as I can remember.
- GWildGuide
ps: the only active system is the system doing the pinging; everything else connected is idle or "off". Besides, a network that can run at 1Gb/s or more should be able to handle a 1 second ping interval without issue.
