GWild
Jul 20, 2020Guide
Latency Spikes
Includes an RBS20 Satellite ... which not seeing it in the pulldown above hints Netgear thinks it is no longer a salable item. Issue is latency spikes between my workstation and the router/modem....
Jul 21, 2020Guru - Experienced User
Are you testing with ALL other devices disconnected from the system while your testing?
Wired or wireless connected when your testing this?
GWild
Jul 22, 2020Guide
Of course this is a normal operating network, all devices are connected (many connect passively while powered off). Latest firmware available installed for router and satellite. Why would anyone expect a router to test perfectly in a perfect setting then stop working when you start to use it in the real world?
It's not so much an occasional slow response as a slow response with dropping packets. This is the first network router I have owned that has dropped ping packets. That's saying something since I've owned routers about as long as I can remember.
- GWildJul 22, 2020Guide
ps: the only active system is the system doing the pinging; everything else connected is idle or "off". Besides, a network that can run at 1Gb/s or more should be able to handle a 1 second ping interval without issue.
