RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
Retired_Member
Oct 21, 2019
RDMSYS wrote:I applied this latest firmware and my satellite is no longer connected.
Why did YOU update?
RDMSYS
Oct 21, 2019Star
I always do when it says theres a new firmware. Why shouldn't I?
- FURRYe38Oct 21, 2019Guru - Experienced User
Please try a factory reset and setup from scratch first to see if you get the system back up and running. Let us know.
https://community.netgear.com/t5/Orbi/New-Firmware-v2-5-0-38/m-p/1813852/highlight/true#M73266
RDMSYS wrote:
I always do when it says theres a new firmware. Why shouldn't I? - Retired_MemberOct 21, 2019
RDMSYS wrote:
I always do when it says theres a new firmware. Why shouldn't I?No...IF your system is working fine, leave it alone. IF a firmware has major updates in it, NG will push it to all.
Also read the release notes.
- RDMSYSOct 21, 2019StarThey did push it. That's why I applied it.
RDMSYS wrote:
They did push it. That's why I applied it.2 methods to FW being applied:
1. They make it available - you see it when you login to your router and you make the decision to apply it.
2. They push is auto and you have no control.
