RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
RDMSYS
Oct 21, 2019Star
I always do when it says theres a new firmware. Why shouldn't I?
Retired_Member
Oct 21, 2019
No...IF your system is working fine, leave it alone. IF a firmware has major updates in it, NG will push it to all.
Also read the release notes.
- RDMSYSOct 21, 2019StarThey did push it. That's why I applied it.
- Retired_MemberOct 21, 2019
RDMSYS wrote:
They did push it. That's why I applied it.2 methods to FW being applied:
1. They make it available - you see it when you login to your router and you make the decision to apply it.
2. They push is auto and you have no control.
Well I assumed that if it's available then it's okay to apply. So, I factory reset the router AND the satellite? And then factory reset the satellite? Then re add the satellite and then import the backed up config file?
