RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
Retired_Member
Oct 21, 2019
RDMSYS wrote:
They did push it. That's why I applied it.
2 methods to FW being applied:
1. They make it available - you see it when you login to your router and you make the decision to apply it.
2. They push is auto and you have no control.
RDMSYS
Oct 21, 2019Star
Also, I downloaded the previous version I had. I guess it's a bad idea to manually update it using them?
- Retired_MemberOct 21, 2019
RDMSYS wrote:Also, I downloaded the previous version I had. I guess it's a bad idea to manually update it using them?
The previous version will take as long as NG is not pushing a later version.
Once your system settles down, leave it alone.
