RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
kyleb88
Oct 22, 2019Guide
All this could be fixed by NG just turning off auto updates...Simple as that, no if ands or buts.
Retired_Member
Oct 22, 2019
kyleb88 wrote:All this could be fixed by NG just turning off auto updates...Simple as that, no if ands or buts.
what would that do? Leave you to decide what FW you install? and...how would you do that?
- kyleb88Oct 22, 2019Guide
NG forces my orbi to update to 2.3.5.30 which kills my wifi. If I run 2.3.1.44 my orbi runs rock solid. This update then says it fixes wifi stability. It does not fix my stability. I do not want to update from my 1.44 firmware.
- CrimpOnOct 22, 2019Guru - Experienced User
Sorry, I was confused by the title of this post: "Latest Firmware V2.5.0.38".
- RDMSYSOct 22, 2019Star
Here we go with the choose thing again. I have been updating my routers firmware for 20 years. It's NOT an OS update. It's a router. You would think that when presented with the message, new firmware is available, that it should be safe to update. That being said, I know that it's not the end of the world when it goes bad but honestly, I can't remember this happening as of recent with any router I've owned in the past.
As far as waiting for consensus on whether a patch is good or not, I mean seriously? I have to check out Netgears forumn first to make sure the patch is okay before I put it on? A week, a month? How long?
- Fallen_MilkmanOct 22, 2019Tutor
I have had the exact same issue. Firmware was updated. Satellites kept showing as disconnected. I ended up having to remove and resync them.
It is also resetting some of my settings every time ti configure them (enabling telnet, splitting the 5Ghz and 2.4Ghz networks into different SSIDs, reset my static IP address settings...). Every time I reconfigure it, within about 20 minutes, they all reset again.
Firmware updates on the orbi have been a crapshoot since I bought it. I end up spending over an hour each time. I can upgrade my nexus 9k/5k/2ks at work faster and more reliably than this thing.
