RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
kyleb88
Oct 22, 2019Guide
NG forces my orbi to update to 2.3.5.30 which kills my wifi. If I run 2.3.1.44 my orbi runs rock solid. This update then says it fixes wifi stability. It does not fix my stability. I do not want to update from my 1.44 firmware.
RDMSYS
Oct 22, 2019Star
Here we go with the choose thing again. I have been updating my routers firmware for 20 years. It's NOT an OS update. It's a router. You would think that when presented with the message, new firmware is available, that it should be safe to update. That being said, I know that it's not the end of the world when it goes bad but honestly, I can't remember this happening as of recent with any router I've owned in the past.
As far as waiting for consensus on whether a patch is good or not, I mean seriously? I have to check out Netgears forumn first to make sure the patch is okay before I put it on? A week, a month? How long?
- Fallen_MilkmanOct 22, 2019Tutor
I have had the exact same issue. Firmware was updated. Satellites kept showing as disconnected. I ended up having to remove and resync them.
It is also resetting some of my settings every time ti configure them (enabling telnet, splitting the 5Ghz and 2.4Ghz networks into different SSIDs, reset my static IP address settings...). Every time I reconfigure it, within about 20 minutes, they all reset again.
Firmware updates on the orbi have been a crapshoot since I bought it. I end up spending over an hour each time. I can upgrade my nexus 9k/5k/2ks at work faster and more reliably than this thing.
- FURRYe38Oct 22, 2019Guru - Experienced User
Did you power OFF both RBR and RBS for 1 minuted then power ON the RBR then RBS to see if the RBS would re-sync on it's own after the FW was updated?
- goldbondxOct 22, 2019Apprentice
For what it is worth..I am back up after 5 hours of time trying to solve. I have not had a drop since last night. I eventually got my satelitte working by hardwiring to my to base, paperclip reset, and then attempting to add satellite again. It said failed while attempting to add..but it showed up anyway. I have not tested to verify if the satelitte is even working correctly as of yet becauase I am still doing yoga and meditation to get over 1/2 my day being wasted yesterday...
The story got better after this though so I thought I would share since ..
Near my witts end yesterday , I sent Netgear a FB messenger asking where to get the last version of firmware. Over a full day later, I get a broadcast " A new firmware (2.50.38) was release on the update server ....." ....They didn't even read my request. Perhaps canned...Netgear is still pushing this crap build.
Anyways, hope this firmware holds up to Black Friday.
- OzzBozOct 24, 2019Initiate
Did you find a fix for the seperate wifi bands automatically joining again? Mine did the same after applying this update - After working perfectly for 18 months. I set up the 2.4Ghz and 5Ghz bands again and it works, but after a few minutes, it rejoins them. Painful, as not everything on my network can deal with band steering.
Ridiculous that we even have to go through the telnet solution in the first place, given not every product can cope with band steering, but then to reset it after you specifically disable it is just plain stupid. The option to turn it off should be in the UI. Basic sh*t!.
- vitaliy_kOct 24, 2019Aspirant
I'm having the same issue with 2.5.0.38. Also, after joining bands I see my upload speed over wifi went down from ~300Mbps to 30-40Mbps. Quite frustrating.
Is there a way to rollback to previous firmware?
- CrimpOnOct 22, 2019Guru - Experienced User
Geez. I'm sorry. OK, I'll stipulate up front, "Netgear is a sorry excuse for a company. Their products are s**t. Support is non-existent. etc. etc. etc." My point was that since this update is an option presented only to users who notice it, there is no harm in waiting to see what other users report. My opinion is that the vast majority of Orbi owners never look at the management system and were blissfully unaware that their Orbi systems updated firmware in the past and are equally unaware that an update is available now. I deliberately did not run out and purchase the WiFi6 model the first day it appeared. I am happy to let others describe their experience first.
