RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
Hixz
Oct 23, 2019Guide
I cannot believe some of the people in this thread blaming users for installing a fw update that was readily available on the web console. Guys-- this isn't a little company and it is 2019. Firmware that is released to the public regardless of whether it is auto-pushed or not shouldn't have these bugs. I could be a new user that just purchased and click check for updates and see there is one available never having stepped on this forum for guidance.
Most smaller companies I've worked for would fire QA leads/teams if this kind of stuff got shipped out. Look at other tech/software companies and you typically can enroll in BETA groups to test firmware that is suspect to have bugs. Netgear should be ashamed of themselves for continuing to release FW that isn't ready for the spotlight-- and blaming it on end users is absolutely asinine.
Oct 23, 2019Guru - Experienced User
Not blaming users, were trying to help them get the system working here. I and others are having good experiences since updating FW. I have done a factory reset which I always do. Some have not done a factory reset and have good experiences still. There are many factors that contribute to bad experiences. Were here to work thru them is all. The more information and feedback we get from users helps us help user with bad experiences.
- RDMSYSOct 23, 2019Star
I don't understand the "factory reset after each update". Why is that necessary? I have updated my firmware maybe 5-6 times since I installed. And nothing happened. Which I expected fully. WHY would you need to do a factory reset EACH time you apply firmware?
I said it yesterday and I'll say it again, ridiculous.
The poor guy above spent 5 hours setting up his network again? I'm not sure it would take me that long but I don't want to have to do it at all.
And I see a lot Netgear isn't that great posts. Well when I was looking at Mesh routers last Janurary they were reccommeded by a lot of people and were a lot of bang for the buch so I went with them.
Now I don't really have any issues with my set up. Everything runs great. But in my mind I think that a FW can only make things better.
Maybe i'm naive.
I was miffed on Monday after doing it blindly and getting semi hosed. But seeing all these other issues I guess I shouldn't complain.
I won't do that again though. I'll wait for the push.
- FURRYe38Oct 23, 2019Guru - Experienced User
IT's NOT required, however it's suggested for those who ARE having problems after FW updates. We've seen odd issues, configurations and lingering bad configuratinos which can cause problem as FW gets updated and progresses. Some do not see this. So in the cases of where users are having problems after a FW update, a reset should be performed and set up from scratch to effect a clean configuration of the system.
- PhilipGoOct 23, 2019Aspirant
If it's a common issue that FW-updates can mess up the system how come you can't just revert to the previous version? I updated when asked since updates usually contain security bugs and other things. Now my router loses internet connection every 30 minutes. And when it does have internet it is super slow on all devices even though the Orbi speed test indicates at least 800 mbit.
