RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
Oct 24, 2019Guru - Experienced User
Known issue already:
schornstadt wrote:Cannot rename attached devices, no matter what.
Cannot change icons in attached devices list.
Joboo7777
Oct 24, 2019Apprentice
I upgraded without issue(for the most part). I run as vanilla a setup as it gets. Only change my DNS to OPENDNS and 2 wifi settings(enabled beamforming and MU-MIMO). I do not use guest access, Armor, or Circle services. Upgrade an rebooted without issue.
I dont really pay attention to the device list all too much. But I did notice that my ring doorbell pro device now has a name of "Homeboy" which was not there before. Anyone else have this?
Thanks
- schornstadtOct 24, 2019Tutor
Thank you for your response.
I have 80 devices and they list OK in version 2.35.35 and I can rename and change icons.
Updated firmware and downgraded several times with the same results.
Cannot rename devices or change icons.
- FURRYe38Oct 24, 2019Guru - Experienced User
You'll have to wait until NG gets this fixed.
schornstadt wrote:Thank you for your response.
