RDMSYS
Oct 21, 2019Star
Latest Firmware V2.5.0.38
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devic...
FWM
Oct 25, 2019Aspirant
First time ever I did a firmware update and had a problem similar to everyone else. After the update finished, my router turned on and 2 of 2 sattelites were disconnected.
Solution for me:
I unplugged the router and both sattelites. Then replugged. Both turned blue, but only one showed up as connected. So I went to the one sattelite that said disconnected and instead of doing the same thing, I took a paperclip and did a reset. And it worked. I'm sure this is a type of problem that has different solutions for everyone, but I'm glad I didn't have to do a factory reset.
