VerneArase
Dec 03, 2019Apprentice
Latest stable Orbi firmware
I see my Orbi RBK53 has 2.5.0.38, but the firmware page for the RBK53 lists 2.3.5.30 (with a hotfix to 2.3.5.34 for certificates). I have noticed a lot of wierd goings on with this firmware, such...
ChuckieCheese
Dec 03, 2019Luminary
FURRYe38 wrote:You can revert to v34.
I have older version. Should I upgrade directly to v34 or upgrade to v30 first and then v34?
Dec 03, 2019Guru - Experienced User
What exact FW version do you have?
- ChuckieCheeseDec 03, 2019Luminary
2.1.4.16.
I will be upgrading to v2.2.1.212 first.
- FURRYe38Dec 03, 2019Guru - Experienced User
After you get the RBR at 212, then you can go directly to v34. You can go directly to v34 on the RBS from where it's at currently.
I would reset the RBR and walk thru the setup wizard after it's fully updated.
- FURRYe38Dec 04, 2019Guru - Experienced User
- ChuckieCheeseDec 04, 2019Luminary
FURRYe38 wrote:Any progress on this?
ChuckieCheese wrote:2.1.4.16.
Not yet. Have to wait for the weekend in case something went wrong... :)
