VerneArase
Dec 03, 2019Apprentice
Latest stable Orbi firmware
I see my Orbi RBK53 has 2.5.0.38, but the firmware page for the RBK53 lists 2.3.5.30 (with a hotfix to 2.3.5.34 for certificates). I have noticed a lot of wierd goings on with this firmware, such...
ChuckieCheese
Dec 04, 2019Luminary
tomschmidt wrote:NG pulled v2.5.0.x from autoupdates due to the issues, but many users got auto-updated to v2.5.0.38 without their knowledge or interaction
I wish Netgear will provide an option to DISABLE auto-update for this very reason.
Dec 04, 2019Guru - Experienced User
v38 was not a forced auto update. It was given as a notification with in the RBRs FW update web page that there was a update available. It would be up to the user to allow the update or skip it. v38 was not a major but a minor update which NG does not force auto updates on minor FW revisions to users Orbi's.
Can do a seach here in the forum about some users disabling auto update. Might work for you if you want to try this.
- ChuckieCheeseDec 06, 2019Luminary
One of the reason I still use 2.1.x.x firmware is because I can disable the auto-update via SSH.
Do you know if for 2.3.5.34 I can still:
1. disable the auto-update for 2.3.5.34
2. have separate SSID for 2.4Ghz and 5Ghz?
- FURRYe38Dec 08, 2019Guru - Experienced User
NG only pushes major versions of FW. Any minor versions will be seen in the RBRs web page as being avaiable however won't be pushed. Its' up to users to select upon the minor FW updates if they want to or not.
ChuckieCheese wrote:One of the reason I still use 2.1.x.x firmware is because I can disable the auto-update via SSH.
