VerneArase
Dec 03, 2019Apprentice
Latest stable Orbi firmware
I see my Orbi RBK53 has 2.5.0.38, but the firmware page for the RBK53 lists 2.3.5.30 (with a hotfix to 2.3.5.34 for certificates). I have noticed a lot of wierd goings on with this firmware, such...
VerneArase
Dec 05, 2019Apprentice
Do you know if 2.5.0.38 had any effect on 5G wireless backhaul?
I've gone through a reformat and restore of my Drobo 8D on an iMac from a Synology hooked ethernet ports on the RBS50 and RBR50, and have gotten about 33 MB/sec throughput (though 100 MB/sec if both are hooked to the RBS50's switch ports).
Dec 05, 2019Guru - Experienced User
I didn't see any negative effects on the backhaul, though mine is wired.
VerneArase wrote:Do you know if 2.5.0.38 had any effect on 5G wireless backhaul?
- VerneAraseDec 10, 2019Apprentice
Well, of course if you're fortunate enough to have a wired backhaul you'll have the full speed of your wired connection (probably a gigabit).
