tallack
May 09, 2019Aspirant
Latest updates nerfed wireless range!!!
No idea why, but the latest update nerfed wireless range! My 2.4GHz devices (doorbell and security cameras) now have horrible, or no, signal. I am in NZ (but they only have Australia country doma...
Sardor
Faced same problems since firmware upgrade to .60. Had to downgrade to .48 to “fix”. Latest version should be pulled and fixed.
- tallackMay 09, 2019Aspirant
I went back to 2.2.1.212 "just to be sure".
Bloody rude of them to nerf the power. :(
- ekhalilMay 09, 2019Master
You can check the transmission power (and change it) in Orbi using the following telnet commands:
root@RBR50:/# iwlist ath0 txpower
ath0 8 available transmit-powers :
0 dBm (1 mW)
6 dBm (3 mW)
8 dBm (6 mW)
10 dBm (10 mW)
12 dBm (15 mW)
14 dBm (25 mW)
16 dBm (39 mW)
18 dBm (63 mW)
Current Tx-Power:18 dBm (63 mW)
Where the interfaces are as follows (in RBR50):
ath0 (Fronthaul 2.4GHz)
ath1 (Fronthaul 5GHz)
ath02 (Guest 2.4GHz)
ath11 (Guest 5 GHz)
ath01 (Backhaul 2.4GHz)
ath2 (Backhaul 5GHz)
- Ragar99May 09, 2019Luminary
I went back to 1.12.0.18 and blocked the auto update a few months ago. The reason was it seemed each new release caused more problems in general and reduced range/throughput specifically.
I asked in these forums which was the "best" firmware and didn't get a very good answer so I picked 1.12.0.18 for two reasons:
This glowing review which was done using 1.12.0.18: https://www.smallnetbuilder.com/wireless/wireless-reviews/33132-wi-fi-system-retest-netgear-ac3000-orbi-and-linksys-velopp
The fact that I don't use/need daisy chain which was introduced in version 2. I am starting to think that adding daisy chain was too much for the Netgear engineering team and that is when this product went South.
I keep trying new releases, but none have the same range/throughput as 1.12.0.18.
