tallack
May 09, 2019Aspirant
Latest updates nerfed wireless range!!!
No idea why, but the latest update nerfed wireless range! My 2.4GHz devices (doorbell and security cameras) now have horrible, or no, signal. I am in NZ (but they only have Australia country doma...
Sardor
Faced same problems since firmware upgrade to .60. Had to downgrade to .48 to “fix”. Latest version should be pulled and fixed.
tallack
I went back to 2.2.1.212 "just to be sure".
Bloody rude of them to nerf the power. :(
- ekhalilMay 09, 2019Master
You can check the transmission power (and change it) in Orbi using the following telnet commands:
root@RBR50:/# iwlist ath0 txpower
ath0 8 available transmit-powers :
0 dBm (1 mW)
6 dBm (3 mW)
8 dBm (6 mW)
10 dBm (10 mW)
12 dBm (15 mW)
14 dBm (25 mW)
16 dBm (39 mW)
18 dBm (63 mW)
Current Tx-Power:18 dBm (63 mW)
Where the interfaces are as follows (in RBR50):
ath0 (Fronthaul 2.4GHz)
ath1 (Fronthaul 5GHz)
ath02 (Guest 2.4GHz)
ath11 (Guest 5 GHz)
ath01 (Backhaul 2.4GHz)
ath2 (Backhaul 5GHz)
- Ragar99May 09, 2019Luminary
I went back to 1.12.0.18 and blocked the auto update a few months ago. The reason was it seemed each new release caused more problems in general and reduced range/throughput specifically.
I asked in these forums which was the "best" firmware and didn't get a very good answer so I picked 1.12.0.18 for two reasons:
This glowing review which was done using 1.12.0.18: https://www.smallnetbuilder.com/wireless/wireless-reviews/33132-wi-fi-system-retest-netgear-ac3000-orbi-and-linksys-velopp
The fact that I don't use/need daisy chain which was introduced in version 2. I am starting to think that adding daisy chain was too much for the Netgear engineering team and that is when this product went South.
I keep trying new releases, but none have the same range/throughput as 1.12.0.18.
- tallackMay 11, 2019Aspirant
I can't ssh to mine, it wont accept connection. But the web gui wireless setup under advanced settings shows both 2.4GHz and 5GHz radios have their TPC set to 100%.
It will be a region thing for sure. I'd say they borked it for ANZ and are getting the EIRP maximum wrong and capping the output to that.
Worked fine when I rolled back (same config, no changes), so I'll just stay on 2.2.1.212 until they get their code worked out. I'll bring home the Ekahau sidekick from work when the new code is released and double check the peaks are the same with the new code.
