WayneU
Nov 09, 2020Aspirant
LBR20 — Orbi LTE Tri-band WiFi Router - Verizon Wireless?
First, I apologize for putting in Orbi Pro in the Location. It would not allow me to put in the LBR20 Orbi. Perhaps the model is too new and the website has not been updated. I have owned the O...
ssmitty67
Nov 10, 2020Aspirant
I have had the Orbi LBR20 since late August and can tell you it does NOT currently work with Verizon. I have constant disconnects and I have been told by Verizon that the IMEI of the device is not recongnized by Verizon.
I have also been told by Netgear that is is not certified with Verizon and they cant tell me excatly when it will be, but couldn be in Q4 or Q1..
I really wish it worked, as when i is not disconnecting, it works great.
Nov 10, 2020Guru - Experienced User
ChristineT Any update on working with Verizon?
