Jr_SF
Jan 26, 2021Aspirant
LBR20 + RBS50v2 - Ethernet backhaul problems
Greetings from Finland, I have an Orbi LTE modem working just fine. Added one satellite last week. Wireless everything was okay. But wired backhaul, what a headache. After several attempts I almos...
CrimpOn
Jan 26, 2021Guru - Experienced User
Jr_SF wrote:My modem/LBR20 is behind 16-port switch. And I couldn't make the wired backhaul working at all.
Problems solved by connecting satellite directly to LBR20.
It would help (me) understand to have a rough diagram of this setup, showing how these components are connected. It makes a huge difference how the satellite is connected to the Orbi.
i.e.
LBR20 LTE modem LAN1 port -> 16 port switch-> RBS50 satellite did not work, but
LAN2 port -> RBS50 satellite does work
Correct?
Jr_SF
Correct.
- CrimpOnJan 26, 2021Guru - Experienced User
There is a constant stream of posts regarding "which switches work" between Orbi router and satellite(s). It is frustrating (to me) that Netgear appears to be silent on the subject. They have no list of "switches that have been proved to work" and "switches known not to work." In addition to green features, there are opinions that any sort of "management", such as IGMP snooping, interferes.
Now that it is working, I (personally) would move on to another activity.
