Franklinstower
Aug 14, 2020Tutor
Lbr20 band lock
Always connects to LTE band 2 In the optimal placement in the house but a sub-optimal placement gets band 66 at double the U/D speeds. Same tower. How can I lock the band to only go to 66?
Mstrbig
Aug 14, 2020Master
Depending on the phone or 4g LTE device you have, you can force channel preferences. My phone allows me to have multiple configurations. The one problem may be you would have to manually switch your device's settings when home.
Have you tried setting the LBR20 to 4G only?
Franklinstower
Aug 14, 2020Tutor
Not sure how to do that. The LBR20 is the new orbi LTE
- MstrbigAug 14, 2020Master
Not sure how to do that. The LBR20 is the new orbi LTERead the documentation.
