Franklinstower
Aug 14, 2020Tutor
Lbr20 band lock
Always connects to LTE band 2 In the optimal placement in the house but a sub-optimal placement gets band 66 at double the U/D speeds. Same tower. How can I lock the band to only go to 66?
ErnestTheGreat
Oct 05, 2020NETGEAR Employee Retired
Hi Franklinstower,
Like any LTE based device there is probably AT commands that can be used to lock the device to specific bands but this is not recommended because you connectivity to the tower is bade on ISP optimization sometimes you may connect to band 2 sometimes band 66 it all depends on how the ISP priorities your device at the time of connection. Sometime you may be moved over to a different band for sake of bandwidth optimization/load balancing on ISP end as they may not want to overload a specific band.
