kolar's avatar
kolar
Follower
Aug 23, 2023
LBR20 drops LTE connection and can't connect again
Hi,
My LBR20 (68N) keeps disconnecting from LTE and can't connect again. It happens with various frequency, sometimes after 1h sometimes after a week. Usually the magenta light turns on after disconnection. If I wont restart the router it will remain disconnected forever. Restarting solves the issue immediately (doesn't matter if I restart it via panel or just cut the power off). I have good LTE connection, base station is just next to my house.
Router firmware version: V2.7.5.6
Mobile firmware version: EG18-EA-PAR01A11M4G
Do you know how to fix it? Maybe there is some workaround like to make automatic reboot once the mobile connection is lost?
No RepliesBe the first to reply
