Viking42
Mar 30, 2021Apprentice
LBR20 internet signal loss
Hello, I hope you can help me, On a LRB20, Router Firmware Version V2.6.4.2 , located in europe Connected to a fiber modem with a LAN cable LTE deactivated Issue: The router emits a wifi...
CrimpOn
Mar 30, 2021Guru - Experienced User
There is a horrible situation that started with the change in Daylight Saving Time that causes certain Orbi RBR50 routers to stop resolving Domain Names until they are restarted. Netgear engineers have traced the problem to a coding error in the Traffic Meter feature. Looks like there is abolutely no chance Netgear will release a firmware fix before April, so the easiest solution is to go into the Orbi web interface, Advanced Tab, Advanced Setup, Traffic Meter (toward the bottom of the menu) and uncheck "Enable Traffic Meter" and Apply.
Viking42
Disabled the traffic meter and changed the NTP just now, i'll report on how that works
- CrimpOnMar 30, 2021Guru - Experienced User
Please follow up. Right now, there are SO MANY posts with similar issues that there is a tendancy to think, "this is what everybody else is experiencing." If it is not, then there this advice may have been not of much use.
- estegMar 31, 2021Guide
CrimpOn wrote:Please follow up. Right now, there are SO MANY posts with similar issues that there is a tendancy to think, "this is what everybody else is experiencing." If it is not, then there this advice may have been not of much use.
Agree.
So much sense.
Regards.
- Viking42Mar 31, 2021Apprentice
Disabled the traffic meter and changed the NTP about 14h hours ago
I just had the internet signal hanging again
So traffic meter is not the solution for me
