Viking42
Mar 30, 2021Apprentice
LBR20 internet signal loss
Hello, I hope you can help me, On a LRB20, Router Firmware Version V2.6.4.2 , located in europe Connected to a fiber modem with a LAN cable LTE deactivated Issue: The router emits a wifi...
Viking42
Disabled the traffic meter and changed the NTP just now, i'll report on how that works
CrimpOn
Mar 30, 2021Guru - Experienced User
Please follow up. Right now, there are SO MANY posts with similar issues that there is a tendancy to think, "this is what everybody else is experiencing." If it is not, then there this advice may have been not of much use.
