Viking42
Mar 30, 2021Apprentice
LBR20 internet signal loss
Hello, I hope you can help me, On a LRB20, Router Firmware Version V2.6.4.2 , located in europe Connected to a fiber modem with a LAN cable LTE deactivated Issue: The router emits a wifi...
esteg
Mar 31, 2021Guide
CrimpOn wrote:Please follow up. Right now, there are SO MANY posts with similar issues that there is a tendancy to think, "this is what everybody else is experiencing." If it is not, then there this advice may have been not of much use.
Agree.
So much sense.
Regards.
Viking42
Mar 31, 2021Apprentice
Disabled the traffic meter and changed the NTP about 14h hours ago
I just had the internet signal hanging again
So traffic meter is not the solution for me
- FURRYe38Mar 31, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi LTE product. Most of the people who watch that forum are more likely to have experience with Orbi LTE and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there since the Orbi LTE is a bit different:
https://community.netgear.com/t5/Orbi-LTE/bd-p/en-home-orbi-lteThank you.
