ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
Mstrbig
Aug 28, 2020Master
ssmitty67 wrote:Since I recieved it 3 days ago, I have been having issues with it sporadically loosing the LTE (verizon) connection which prompts me to have to reboot the router to fix it. Wondering if this is a potential known problem and if so, are there any possible fixes?
I have solid cellular service and swapped the SIM out of my old Verizon jetpack (which had it own issues - battery overheating).
It auto configured itself to use vzwinternet for the APN.
Thanks,
Matt
One thing that may be causing it is low signal. Can you see what the signal strength is for the LTE connection?
Second, Verizon may not be fully supported on the LBR20 yet.
ssmitty67
I attached the mobile status info the router provided. It shows I have pretty decent signal with a RSRP value of -94 dBm. Im consistently getting 35 meg dl throughput when the router is up. So based on this I am shying away from low signal being the culprit.
Do you happen to have any additional information about the router not supporting Verizon? It includes Verizon's Band 13, so it seems to been built to at least accomdate Verizon.
Thanks,
Matt
- MstrbigAug 28, 2020Master
ssmitty67 wrote:I attached the mobile status info the router provided. It shows I have pretty decent signal with a RSRP value of -94 dBm. Im consistently getting 35 meg dl throughput when the router is up. So based on this I am shying away from low signal being the culprit.
Thanks,
Matt
OK so you are connected to the Verizon network, so it still may be signal.
A couple of things to check:
What are your roaming settings, maybe take off roam?
Try setting the network mode to 4G, instead of auto.
The Verizon Wireless LTE bands are 2, 4, 5, 13, 46, 48, 66
- ssmitty67Aug 28, 2020AspirantI’ll give those a try and monitor
Thanks for your suggestions.- darwin1991Aug 28, 2020Guide
I have the same issue like yours too! I'm using AT&T sim and I just got it setup yesterday with less than 48 hours of use, suddenly the internet didn't work and I need to reset the LBR20 to bring back the internet. Hopefully this can be addressed on next firmware update.
- frank199Oct 14, 2020Aspirant
I have the same issue as well. Intermittently I will lose the internet connection. Rebooting the router does not reconnect the VZ wireless LTE connection, I have to power off the unit.
Router firmware:
V2.5.2.20
Cellular Modem firmware:
EG18-NA-PAR01A05M4G- ssmitty67Oct 15, 2020Aspirant
Curious, is your account pre or post pay? My suspicion is the pre pay accounts (what I have) have some sort of of IMEI conflict with Verizon. I have not been able to get an answer out of Netgear if the LBR20 is certified with Verizon (or not). There was some chatter about it in another thread, but nothing definitive.
