ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
darwin1991
Aug 29, 2020Guide
My home internet is 4G LTE sim from ATT. It is a hotspot.
Mstrbig wrote:
darwin1991 wrote:I have the same issue like yours too! I'm using AT&T sim and I just got it setup yesterday with less than 48 hours of use, suddenly the internet didn't work and I need to reset the LBR20 to bring back the internet. Hopefully this can be addressed on next firmware update.
Can you be more specific?
The internet you are referring to, is it ISP provided or 4G/LTE?
Mstrbig
Aug 29, 2020Master
darwin1991 wrote:My home internet is 4G LTE sim from ATT. It is a hotspot.
Is the 4G/LTE the only internet you have or do you have an internet servoce provider as well, (cable internet and 4g/LTE)?
- darwin1991Aug 29, 2020GuideIt is my only internet service provider.
- MstrbigAug 29, 2020Masterwhat is your 4g/LTE signal strength
