ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
Mstrbig
Aug 28, 2020Master
ssmitty67 wrote:I attached the mobile status info the router provided. It shows I have pretty decent signal with a RSRP value of -94 dBm. Im consistently getting 35 meg dl throughput when the router is up. So based on this I am shying away from low signal being the culprit.
Do you happen to have any additional information about the router not supporting Verizon? It includes Verizon's Band 13, so it seems to been built to at least accomdate Verizon.
Thanks,
Matt
OK so you are connected to the Verizon network, so it still may be signal.
A couple of things to check:
What are your roaming settings, maybe take off roam?
Try setting the network mode to 4G, instead of auto.
The Verizon Wireless LTE bands are 2, 4, 5, 13, 46, 48, 66
frank199
Oct 14, 2020Aspirant
I have the same issue as well. Intermittently I will lose the internet connection. Rebooting the router does not reconnect the VZ wireless LTE connection, I have to power off the unit.
Router firmware:
V2.5.2.20
Cellular Modem firmware:
EG18-NA-PAR01A05M4G
- ssmitty67Oct 15, 2020Aspirant
Curious, is your account pre or post pay? My suspicion is the pre pay accounts (what I have) have some sort of of IMEI conflict with Verizon. I have not been able to get an answer out of Netgear if the LBR20 is certified with Verizon (or not). There was some chatter about it in another thread, but nothing definitive.
- frank199Oct 15, 2020Aspirant
I'm on the play more unlimited plan with VZ, rural area, works great when it's working but just drops the internet connection on an intermittent basis. I have to power off the unit to get it back online, a router reboot doesn't appear to do anything. My received signal quality is in the minus 70's, RSRP -105 range, RSRQ -9 .... all in all I'm getting anywhere from 37Meg up to 90Mbs download and anywhere from 5 to 10 up without an antenna... works great until the modem disconnects...
- PersistentHackOct 16, 2020Star
Hi NETGEAR Communitiy,
Count me in among the folks encountering these apparently random and somewhat long lasting LTE disconnects as well. Good RSRP, SINR, and data rates. Using internal antennas. FWIW, Verizon gUDP. Rebooting doesn't solve the problem. It just decides to come back at some point. Works great for hours on end and then suddenly seems unable to maintain a connection. Connects to the network, disconnects a few seconds later, process repeats several times before it seems to give up. Other devices (phones & USB modem) connect to the same tower and work reliably - albeit more slowly.
Will do some more diagnostics... But I sure hope this is fixable. This is the most cost-effective option I have for decent primary internet right now.
