ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
darwin1991
Oct 17, 2020Guide
Surprisingly I’m not the only one experiencing this problem. Up to now I’m still dealing with this problem. Sometimes more than 2 times in day of disconnection with full bars of signal and sometimes the connection comes back after 5 minutes and sometimes it requires me to remove reboot the lte router.
frank199
Oct 19, 2020Aspirant
Thought I would provide an update... I disconnected my lan connection - I had it connected to an ethernet switch. I have also added in ipv6 as a protocol. So far I am 2 days and 3 hours online...... I'm not certain if this due to the lan connection or to the ipv6 change.... If I go for 4 days without any drops I'll reconnect the lan and monitor.
Does anyone know of a telnet or ssh process to issue an AT command to reboot the modem?
