ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
Whackodingo
Dec 01, 2020Aspirant
Having the same problem of LTE dropping but using AT&T sim. Rebooting brings back temporarily. Called Netgear support and they had me refresh the firmware V2.5.2.20 manually using file downloaded from Netgear website. Will see how long it lasts.
darwin1991
Dec 01, 2020Guide
I have the same problem as you do. I'm using AT&T sim, LBR20 keeps losing signal, sometimes it took around 5 minutes then the internet comesback and sometimes it requires rebooting.
