ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
Franklinstower
Dec 05, 2020Tutor
any luck on the manual refresh of the firmware?
PersistentHack
Dec 05, 2020Star
2.5.2.20 is the original firmware. Unless you flashed new, reflashing the original over the original is unlikely to do anything particularly useful. I did a (support-recommended) full factory reset on mine (which also reflashes the firmware) and it did not help.
My guess is either a bug in that original firmware or an incomplete understanding between NETGEAR and carriers on the status of this device's approval for use on said carriers' networks.
- ssmitty67Dec 08, 2020Aspirant
I started this thread back in August and I wanted to rant a little bit about my experience.
I got a replacment unit last week after arguing with Netgear support for hours on the phone (and with hardly any meaningful response via email). It was excruciatingly painful as I was transfered from team to team having to explain the situation over and over. I was trying to just return the unit , but they did not want to let that happen as I was past my 30 day window (despite the fact I logged a ticket a few days after I recieved the device). So I settled for a RMA, I was extremely skeptical that it would be any different and my skeptisim turned out to be true as the new unit has the same disconnect issues.
My best guess of what is happening is that Verizon is blacklisting the IMEI as it is not a supported device (certified) on VZ's network and thus causing the disconnects - how this is being accomplished is unclear to me (others have suggested some ideas on this thread)
So I was going to the support page to indicate that the RMA did not work and I discovered that since I am past my 90 day support window, I dont have the ability to open a case (as they closed all my other cases - even thought I repeatedly asked them not to)
I guess my only recourse is to call in again, but I know that will be an experience from hell (based on my previous call) and I doubt that even though they told me I could return the unit if the RMA didnt work, Im sure they will not honor (Im sure the agent told me that to get me off the phone).
Does anyone here have any advice to get Netgear to take this unit back? I feel like I put a lot of good faith into trying to get this to work with Netgear(and I really wish it did).
I feel that Netgear misrepresented this router. Initially (when I purchased) it was advertised as compatible with Verizon. But now it is advertised as Tmob & ATT compatible only.
Am I stuck with this device? Is it a $400 paper weight?
- FranklinstowerDec 08, 2020TutorAdvertised as working with ATT yet it constantly loses connection as well. This thing is expensive junk at this point.
- cnwdonDec 09, 2020Tutor
I have one LBR20 purchased direct from Netgear last summer that has been working with our Verizon 4G LTE cell service for about 4 months now, for a 9 hour workday, no problems with "dropping out" like others have posted above. But, I just bought a second LBR20 which now does NOT work with Verizon cell service (we do not have the FiOS fiber available where we live, or any other cable or fiber option).
Does someone have more information about this issue from Netgear or your experience? If the problem is Verizon changing its compatibilty permissions, I don't know why the first LBR20 continues to work fine with our Verizon 4G LTE service.
Hours on hold with both Netgear and Verizon have not helped me find any authoritative information. A Netgear tech support person told me this morning that it should work with Verizon, but when I asked her to double check that she put me on hold again and the call was dropped before any more answers were obtained. I see current sales information saying the model is not compatible with Verizon.
We need a similar router that has coax input(s) for an external antenna. Our Verizon signal is not strong enough for acceptable connection speed without the connection to an external directional antenna that the LBR20 offers.
Helpful information, anyone? Alternative routers for Verizon with antenna input? Thanks
- ng-user1Dec 20, 2020Aspirant
No 4g connection on LBR20 for Tmobile. Only connects to HSPA+ band 96. 8Mb max throughput. Very disappointing. I have spent hours with tmob tsch service to no avail. my phone and a tmob provide Franklin hotspot work without issues on 4g network at 50+ Mb. LBR20 will only connect when3G or Automatic is selected in the network mode. It wont connect at all when 4G is selected in the network mode. Thankfully its returnable until after christmas. I will keep trying and update this if anything changes.
- FranklinstowerJan 01, 2021TutorAny updates on a fix for att?
- Christian_RDec 11, 2020NETGEAR Employee Retired
Hello Community users,
If you're experiencing issues regarding the LBR20, may you provide me with the following info. I'd like for our support team to reach out for further investigation.
Name:
Email:
Phone:
Serial Number:
Thank you,
Christian
- PersistentHackDec 11, 2020Star
Hi Christian,
Thanks for the offer of help. PM sent.
- cnwdonDec 12, 2020Tutor
Christian: Please respond to the question above. Note this Netgear web page shows Verizon as a supported carrier for LBR20:
https://kb.netgear.com/29947/List-of-Carriers-Supported-by-Netgear-Mobile-Devices
Is this information out of date and Verizon is not available with the LBR20?
Or can you please get reliable information about why some of us cannot use Verizon LTE cell service with our new LBR20 routers? Is there information from your corporate sources about the relationship with Verizon, and is that broken? Please get us some accurate information.
