ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
RuralRob
Feb 12, 2021Aspirant
Franklinstower wrote:
Firmware updated to 2.6.3.50
https://kb.netgear.com/000062877/LBR20-Firmware-Version-2-6-3-50
Anyone notice a difference?
Nice Find!!! Auto updates don't find this. I always forget to look for manual update availability. Installed. We will see.
Franklinstower
Feb 12, 2021Tutor
I check daily. I am not going to move back to this device until you all confirm that it fixed the problems. I need to swap out to a new sim again and don’t want to do that until I know it’s been fixed.
- WaltOFeb 12, 2021TutorMR5100 on eBay for $400 sold my Orbi and my new MR1100 financed by ATT for a total of $400.
No issues stable for days. Reboot occasionally to reset speeds. No issues with disconnects. It even buffers for awhile very rarely but it catches up and does not disconnect .- WaltOFeb 12, 2021TutorOrbi and MR5100 use Nano sim making the regretful switch a little easier
- FranklinstowerFeb 12, 2021TutorHow does the 5100 compare to the 1100 in real world performance?
- WaltOFeb 12, 2021TutorNot ad good as the Orbi when working perfectly... but it does not give up you see it in every Speedtest it pushes and pushes up and down
- RuralRobFeb 14, 2021Aspirant
Knock on wood...I've gone over 24 hours without a disconnect after the firmware upgrade to 2.6.3.50 and a factory reset. Now, my usage is lower on the weekends so we will see how it goes tomorrow.
- FranklinstowerFeb 14, 2021TutorSpoke too soon. The firmware update did not resolve the problem. Two disconnects today.
- RuralRobFeb 15, 2021Aspirant
I've now gone 48 hours without an issue!
