ssmitty67
Aug 28, 2020Aspirant
LBR20 keeps disconnecting from LTE
I just got one of the new LBR20 Obri routers with LTE connection. I was looking forward to this product for quite a while as I live in a rural area without high speed access and all I have available...
terabull
May 01, 2021Aspirant
Just to be clear, I have legit ATT sim from isp. When it works its great, but I have to reboot the router many times per day with the router saying "detecting". This seems like something that could easily be figured out.
- BobTechJun 13, 2021Aspirant
I am in the same boat. A fresh AT&T SIM and it locks up under heavy Zoom traffic. Consistently. I called Tech Support. They said I have the latest firmware and it is AT&T's fault. I am past the return window. It works great when it is not needed. But when peak traffic occurs, it crashes, says detecting for the LTE and has to be rebooted. I am soooo disappointed because when it works, it works well. Just not when I need it.
- Blanca_OJun 21, 2021NETGEAR Employee Retired
Hi BobTech
You mentioned that device is on the latest firmware, can you please provide the firmware version?
Kindly describe the ring LED status when issue re-occur.
Have you tried resetting the device?
Blanca
Community Team- BobTechJun 21, 2021Aspirant
You mentioned that device is on the latest firmware, can you please provide the firmware version? V2.6.4.2
Kindly describe the ring LED status when issue re-occur. The rings were either off or blinking white.
Have you tried resetting the device? I did factory reset the device after posting. It does seem to have improved things. I have not had a crash since the factory reset. I was in a Zoom meeting for a couple of hours without a crash, something I could not previously do. And as a test, I downloaded and uploaded a large Windows ISO file with no issues. It previously seemed that the device would crash when traffic was really busy. So, hopefully we are past the initial problems.
