kryysler
Apr 18, 2021Aspirant
LBR20 no internet access, Elisa ISP (Finland)
Hi, I'm new to the community and hoping someone can help me out. Bought a LBR20, set it up per the instructions as LTE only, but cannot get the internet access to work. My case seems to be exactly the same as this one https://community.netgear.com/t5/Orbi/4G-LTE-WiFi-Orbi-Router-Model-LBR20-LTE-Connection-failure/m-p/2056158, also using a Finnish ISP (Telia).
I've tried the mobile app, the web interface, entered ISP APNs, reset factory settings, upgraded firmware to 2.6.4.2 (latest), tested SIM in another device where it works perfectly.
The connection check shows the SIM as "ready" but no connection, no IP, no nothing.
Have anyone else experienced something similar, and if so, did you manage to resolve it?
