Viking42
Aug 19, 2020Apprentice
LBR20 Router / AP Mode option greyed out
Hi Using a LBR20 with two RBS20 satellites the LBR20 is connected on WAN plug to my fibre modem Router Firmware Version V2.5.2.20 going to http://orbilogin.net/, the advanced/advanced se...
CrimpOn
Aug 26, 2020Guru - Experienced User
It seems pretty clear (to me) that "what is the point?" is the important question. People who deliberately purchase an LTE WiFi router generally have one of two goals:
- Their only broadband option is LTE (no cable, fiber, or DSL). In that case, the LTE device cannot be in AP mode.
There would be no router to give the any devices an IP address. Makes no sense. - They want the LTE modem to be a "failover" for their primary ISP. (This is a valid solution to an unstable ISP or to a need for guaranteed network connection.)
In this case, the LTE device cannot be in AP mode, because when it fails over there will no longer be any way for any attached devices to get an IP address.
Buying an LTE device with the intention of never using LTE seems a bit unusual. Blanca_O provided instructions for how to set the LTE device to "never use LTE" and thus be capable of AP mode.
If the goal is to keep using the primary ISP router as the DHCP server, but "fail over" to LTE when the ISP service goes down, then it is simply not going to work. Imagine this: every device in the house knows through DHCP that the ISP device is the internet gateway. The ISP service goes down, so the LTE device activates LTE mode. All the devices "know" that the gateway is through a device that no longer works. The LTE modem is NOT the gateway, and has no way to become the gateway. The network cannot "fail over".
Mstrbig
Aug 26, 2020Master
CrimpOn I've thought the same thing since day one, when we first started installing them. Hence the reason why we only set them up the one way with automatic failover support on.
One would be better off purchasing a regular Orbi system and getting a hot spot device from their ISP.
- Viking42Aug 28, 2020Apprentice
Hi,
Thansk for all the answers!
The setup:
- A fiber modem is connected to the WAN port, signal works fine
- A Sim card is inserted in the orbi and the signal works fine (tested in always 3G/4g to make sure)
- I bought this specific router for the failover option, The Orbi is configured in failover mode
- The orbi is configured in DHCP
Two issues1) When My fiber modem is still up but i recived no internet signal from fiber line, the Orbi router does not switch to 3G/4G: It seems the orbi assumes that as it still gets a signal from the fiber modem, but without internet connection, everything is fine
2) I am still looking for a way to have my orbi taking over the fixed IP's assigned by my fiber modem
thanks!
- Viking42Sep 05, 2020Apprentice
So i tried to deactivate the DHCP, the clean way with fiber modem reboot and orbi reboot
A real mess, none of my devices recieved an IP adress, i was unable to access the modem this way and reactivate the DHCP, it ended in a full reset.
I'm still ver blocked with my issues, any insider tipp would help me a lot
The setup:
Two problems1) When My fiber modem is still up but i recived no internet signal from fiber line, the Orbi router does not switch to 3G/4G: It seems the orbi assumes that as it still gets a signal from the fiber modem, but without internet connection, everything is fine
2) How have my orbi taking over the fixed IP's assigned on my fiber modem
thanks!!
