Viking42
Aug 19, 2020Apprentice
LBR20 Router / AP Mode option greyed out
Hi Using a LBR20 with two RBS20 satellites the LBR20 is connected on WAN plug to my fibre modem Router Firmware Version V2.5.2.20 going to http://orbilogin.net/, the advanced/advanced se...
Viking42
Aug 28, 2020Apprentice
Hi,
Thansk for all the answers!
The setup:
- A fiber modem is connected to the WAN port, signal works fine
- A Sim card is inserted in the orbi and the signal works fine (tested in always 3G/4g to make sure)
- I bought this specific router for the failover option, The Orbi is configured in failover mode
- The orbi is configured in DHCP
Two issues
1) When My fiber modem is still up but i recived no internet signal from fiber line, the Orbi router does not switch to 3G/4G: It seems the orbi assumes that as it still gets a signal from the fiber modem, but without internet connection, everything is fine
2) I am still looking for a way to have my orbi taking over the fixed IP's assigned by my fiber modem
thanks!
Viking42
Sep 05, 2020Apprentice
So i tried to deactivate the DHCP, the clean way with fiber modem reboot and orbi reboot
A real mess, none of my devices recieved an IP adress, i was unable to access the modem this way and reactivate the DHCP, it ended in a full reset.
I'm still ver blocked with my issues, any insider tipp would help me a lot
The setup:
Two problems
2) How have my orbi taking over the fixed IP's assigned on my fiber modem
thanks!!
