Zanderson1198
Jul 03, 2021Follower
LBR20 showing internet offline
I am using the LBR20 as a LTE modem and router. When going into the app the internet says offline but if i test my speeds it says I’m getting good speed but doesn’t send out any signal. It worked perf...
Blanca_O
Jul 06, 2021NETGEAR Employee Retired
Welcome to NETGEAR Community!
Who is your Internet Service provider?
What is the firmware version?
Kindly contact your Internet provider to ensure that you have the correct data plan for LBR20.
Blanca
Community Team
