GundarooPH
Dec 01, 2020Initiate
LBR20 support for dual polarity external antennas in MIMO configuration
Hi folks, Looking to buy the LBR20 and cannot find any explicit confirmation that it supports MIMO using dual polarity antenna setups (whereas the Nighthawk M1 specs do state that it supports MIMO o...
Blanca_O
Dec 14, 2020NETGEAR Employee Retired
Hi GundarooPH
Welcome to NETGEAR Community!
The LBR20 has full MIMO function even if an SMA antenna isn't connected.
LBR20 default antennas are dipole antenna design. If you plan to use an external antenna, it should be a dipole antenna as well. Directional antennas should not be used, since it will result in a bad performance because it could not point to a base station directly.
Blanca
Community Team
- MEDUCK7Dec 15, 2020TutorHello, Do you have any samples to select for dipole antenna for LBR20?
- jjborjeJan 07, 2021Initiate
Hi Blanca,
Can you explain the reason why a directional antenna would not work? It seems so odd to have external connectors and not be able to point to a base station.
I was just about to buy the LBR20 and find a directional antenna.
Thanks,
Johan
- GundarooPHJan 07, 2021Initiate
I second your question Johan.
AFIK a Yagi directional antenna IS a dipole antenna. The definition of a dipole antenna is that it has two even rods either side of the mast to pick up the signal. The yagi antenna is just a set of thse balanced rods.
I suspect that Blanca meant to say that the omni-directional antenna is not recommended (rather than the directional antenna). By definition, the omni-directional antennas are not dipole.
Happy to be told otherwise.
- jjborjeJan 08, 2021Initiate
Thanks Gundaroo,
Blanca, maybe you could confirm?
Thanks,
Johan
