djirez
Jun 30, 2022Aspirant
LBR20 upnp not available under advanced settings
I am using the Orbi LBR20 with Verizon.
I do not see the option to enable UPNP under "Advance settings".
I went to all the tabs and it is no where to be found.
What is the possible cause and how can I remedy it?
Thanks in advance for any help.
- KevinLiTNETGEAR Moderator
Hello djirez,
Welcome to the NETGEAR Community!
I understand that you are looking for the UPnP settings on your LBR20.
To enable UPnP please do the following:
- Enter orbilogin.com
- Select ADVANCED > Advanced Setup > UPnP.
- Select APPLY
For more information about UPnP for your LBR20 navigate to the link below:
https://www.downloads.netgear.com/files/GDC/LBR20/Orbi_LBR20_UM_EN.pdf
Best,
Kevin
Community Team
