Chris075
Jul 13, 2022Aspirant
LBR20 using hotspot data instead of LTE
I just purchased the Orbi LBR20 and a plan on Mint Mobile. worked fine for about 2 days, then it used all the 5gb of hotspot data. Shouldnt this use straight LTE data and not hotspot data? How do I s...
KevinLiT
Jul 13, 2022NETGEAR Moderator
Hello Chris075,
Welcome to the NETGEAR Community!
The LBR20 can only be used with data plans. The hotspot that you have with Mint Mobile is considered a data attachment to your cellular service. This caused your LBR20 to use the hotspot data instead of your cellular data.
An additional data plan is needed for your LBR20.
Best,
Kevin
Community Team
- Chris075Jul 13, 2022Aspirant
So even though the SIM was purchased and has unlimited data and technically for a phone, it is still going to try and use it as a hotpost?
- KevinLiTJul 13, 2022NETGEAR Moderator
Hello Chris075,
The unlimited data you are referring to is the unlimited cellular data plan provided by your carrier.
Best,
Kevin
Community Team
- plemansJul 13, 2022Guru - Experienced User
Mint mobile can tell that its in a cellular modem and not connected using a phone.
they specifically don't have a modem plan because they're a reseller of tmobile's data.
