Chris075
Jul 13, 2022Aspirant
LBR20 using hotspot data instead of LTE
I just purchased the Orbi LBR20 and a plan on Mint Mobile. worked fine for about 2 days, then it used all the 5gb of hotspot data. Shouldnt this use straight LTE data and not hotspot data? How do I s...
Chris075
So even though the SIM was purchased and has unlimited data and technically for a phone, it is still going to try and use it as a hotpost?
KevinLiT
Jul 13, 2022NETGEAR Moderator
Hello Chris075,
The unlimited data you are referring to is the unlimited cellular data plan provided by your carrier.
Best,
Kevin
Community Team
