cnwdon
Apr 14, 2020Tutor
LBR20 with Airport Extremes as extenders
We now have 2 Airport Extremes connected by Ethernet cable to Netgear switch, which connects to our cellular modem. We plan to buy the new Orbi Mesh LBR20 when available, because it will work with V...
- Apr 14, 2020
IF thats what you use to connect your phone and other wifi devices to, then yes.
SSID names can be anything and be intuitive as well. You don't have to use default SSID names for your wifi network for your home devices.
cnwdon
Apr 14, 2020Tutor
Thanks. If I understand things right, the SSID is the "name" in my list of connection choices, in this case "Verizon-4GLT-BRV-5437". Do you mean that I would "name" the LBR20 with that moniker, and use the existing password?
Apr 14, 2020Guru - Experienced User
