chicagod
Aug 23, 2020Guide
LBR20 with Verizon
I have purchased the LBR20 and Verizon will not activate it (even though it is compatible with their LTE bands). If you plan to use this with Verizon, do not purchase it.
- Aug 27, 2020
chicagod wrote:
ChristineT wrote:Good morning chicagod,
Yes, I can confirm this will be certified in the upcoming weeks barring any unforeseen complications. I'm using my Verizon SIM and connected to the internet while I write this! :-) I also have a JetPack so it we need to troubleshoot together I'm happy to continue working with you directly.
Thanks for your additional feedback Mstrbig! T-Mobile is the backbone of Clearway so that's definitely an optimal configuration! :-)
If I can be of any further assistance please feel free to continue to @ mention me! :-)
Cheers,
Christine
I just tried to use the activated SIM from the Jetpack in the LBR20, adn unfortunately it did not work. I even tried changing the MAC address to that on the Jetpack. Again, you can see on the connection status that there is a good connection. Unless there are some configuration options that are not set properly, I guess I will have to wait for Verizon certification.
OK... as a last ditch effort, I went into all of the settings on the Jetpack and noticed that it said APN: VZWINTERNET. I entered this into the Orbi and it works!!!
WindeaterOK
Aug 31, 2020Tutor
I replicated chicagod's solution -- pulled the nano SIM from a working Jetpack, put it in the LBR20, made sure the vzwinternet was in the APN setting, and VIOLA! my LBR20 is now connected to the Internet.
- MstrbigAug 31, 2020Master
WindeaterOK wrote:I replicated chicagod's solution -- pulled the nano SIM from a working Jetpack, put it in the LBR20, made sure the vzwinternet was in the APN setting, and VIOLA! my LBR20 is now connected to the Internet.
BRAVO!
