ThurmJ
Jun 29, 2018Aspirant
LED blinking Continuously blinking White
After a power outage at my home, I reset my modem and then my Orbi Router. The Orbi Router has a white blinking ring that will not stop. I tried using the app and tried setting up a new system as well...
ThurmJ
I am not familiar with how to update firmware on a router that cannot connect to my network. If this is the suggestion, please give me a detailed easy to follow way to do this please. I have been reading similar post to this, and cannot find a direct answer. I really don’t want to have to spend another $350 for a whole new system, this one is less than 7 months old.
Jun 30, 2018Guru - Experienced User
Is the LED blicking ON and OFF or slowly plusating on and off?
Did you hold the reset button untill the top led turned on Amber then let go? IT should then blink ON and OFF White, then slowly plusate On and Off WHITE.
Is your PC getting a IP address from the router when LAN cable connected?
