Rumpelstiltskin
Apr 22, 2018Follower
LED lights
Does anyone know of way to turn the LED lights off on the Orbi Router and Satellites?
Apr 22, 2018Guru - Experienced User
They should turn OFF automatically when running normally after set up. There only on when there is problem:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- schumakuApr 23, 2018Guru - Experienced User
Only the small green power LED on/in the power button is always on when the system is on.
