Tedmh
Jul 16, 2017Aspirant
LED ring solid white on Router
I reset orbi router to factory settings and tried to start up again. It gets to solid white ring light and solid green power LED and that's where it stays. Tried resetting again and got the same...
- Jul 23, 2017So I ended up hard resetting everything. Got it back to where the router would work. Left my house came back and the satellite had connected its self back to the router. Got on to check everything the the satillite was able to do a firmware update and everything has been great since. Was able to unplug the satillite and move back up stairs. It connect again right away with no issue. So basically I just factory reset everything start over and left it alone. Also note I do have it running as a access point now instead of router mode.
DarrenM
Jul 18, 2017Sr. NETGEAR Moderator
Hello Tdmh
Do you have a RBK50 unit or a RBK40 unit?
DarrenM
Tedmh
Jul 22, 2017Aspirant
Hi Darren
rbk50. Sorry I left that out in previous post.
Thanks
- rustichippoJul 22, 2017AspirantSame issue. Hard reset for modem. Now the modem light is solid white, one satellite is solid blue, and one is solid purple. I'd love to know if your issue gets fixed.
- tlubackerJul 23, 2017AspirantSo I ended up hard resetting everything. Got it back to where the router would work. Left my house came back and the satellite had connected its self back to the router. Got on to check everything the the satillite was able to do a firmware update and everything has been great since. Was able to unplug the satillite and move back up stairs. It connect again right away with no issue. So basically I just factory reset everything start over and left it alone. Also note I do have it running as a access point now instead of router mode.
- TedmhJul 23, 2017Aspirant
That's great to hear. Two questions:
- what exactly is a "hard" reset and how do you do it on the rbk50?
- Why are you running the unit as an access point instead of a router?
Thanks
