smojsak
Dec 29, 2018Aspirant
LED ring solid white
Hi.
I have a solid white light on my Orbi router but my satellites are with solid blue or red then blue.
I saw some people are having the same issues and said to download new firmware but w...
ekhalil
Dec 29, 2018Master
smojsak wrote:
Hi.
If the Satellites have blue rings then you should be fine. What problems do you see in your network? Can you see your wifi networks and have internet access?
- smojsakDec 29, 2018Aspirant
Hi
One of the satellites is now moving from blue to red and then to no colour and stays with no colour for most of the time.
I can see a Orbi network (full signal) to join but I tried now on my laptop it states "Can't join this network"
Any ideas? I am tempted to just send the whole thing back and order a new one or different one entirely.
- ekhalilDec 29, 2018Master
smojsak wrote:
Hi
- Are you able to login to the Orbi GUI (orbilogin.com)?
- What ISP modem/router are you sung and is it just a modem or is it a router?
- Pleas make sure first that the Router is up and running and you can login to the router, then get the satellites up one by one.
- FURRYe38Dec 29, 2018Guru - Experienced User
Factory reset this satellite as well using same process as I suggested for router. Then try to re-add it to the router.
smojsak wrote:
Hi
