smojsak
Dec 29, 2018Aspirant
LED ring solid white
Hi.
I have a solid white light on my Orbi router but my satellites are with solid blue or red then blue.
I saw some people are having the same issues and said to download new firmware but w...
ekhalil
Dec 29, 2018Master
smojsak wrote:
Hi.
If the Satellites have blue rings then you should be fine. What problems do you see in your network? Can you see your wifi networks and have internet access?
smojsak
Hi
One of the satellites is now moving from blue to red and then to no colour and stays with no colour for most of the time.
I can see a Orbi network (full signal) to join but I tried now on my laptop it states "Can't join this network"
Any ideas? I am tempted to just send the whole thing back and order a new one or different one entirely.
- ekhalilDec 29, 2018Master
smojsak wrote:
Hi
- Are you able to login to the Orbi GUI (orbilogin.com)?
- What ISP modem/router are you sung and is it just a modem or is it a router?
- Pleas make sure first that the Router is up and running and you can login to the router, then get the satellites up one by one.
- FURRYe38Dec 29, 2018Guru - Experienced User
Factory reset this satellite as well using same process as I suggested for router. Then try to re-add it to the router.
smojsak wrote:
Hi
