jojo2go
Jan 10, 2017Apprentice
Lessons Learned for best Orbi experience
Hi All, Clearly a lot of us are having issues (some major, some minor, some common, some not). Not sure how many of these issues are due to unfamilarity with the system, operator error, or outri...
- Jan 14, 2017
Turned out I had some hardware issues with my Orbi. After continued speed issues (instablity) on my satellite, I exchanged my Orbi 3-pack system at Coscto for a new system, and now I am up and running at full, stable speeds on both the router and satellite. Case closed!
CDELL801
Jan 11, 2017Aspirant
Will try turning mine down, have devices also sticking to the router with poor signal when it's closer to a satellite, thank you.
- jojo2goJan 11, 2017Apprentice
Does the "beam forming" optionbeing enabled have any impact on devices 'sticking' to either the router or satellite, as you move closer to the other?
