rozzer7777
Dec 12, 2020Initiate
level 2 support
I know there are many posts here with horror stories about tech support... This is NOT one of them. I had a problem with my RBS50 satellite dropping connection with the router. I had checked some po...
Dec 12, 2020Guru - Experienced User
Glad to hear a positive experience on here! We tend to only see the complaints and it makes us a bit jaded at times. :)
- FURRYe38Dec 12, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849Enjoy.
