Frizzy
Aug 20, 2018Follower
Leviton Smart Decora switches randomly disconnecting
Anyone have issues with Leviton Smart Decora switches disconnecting? I am having this issue and others have brought up that possibly forcing seperate SSID's for 5 and 2.4 might help, anyone notice s...
Aug 20, 2018Guru - Experienced User
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Set up IP address reservations ON the router for the satellites and your devices. Wired or wireless connected.
